The Decision Making Process
The importance of learning and understanding effective aeronautical decision-making (ADM) skills cannot be overemphasized. While progress is continually being made in the advancement of pilot training methods, aircraft equipment and systems, and services for pilots, accidents still occur. Despite all the changes in technology to improve flight safety, one factor remains the same: the human factor which leads to errors. It is estimated that approximately 80 percent of all aviation accidents are related to human factors and the vast majority of these accidents occur during landing and takeoff.
ADM is a systematic approach to risk assessment and stress management. To understand ADM is to also understand how personal attitudes can influence decision-making and how those attitudes can be modified to enhance safety in the flight deck. It is important to understand the factors that cause humans to make decisions and how the decision-making process not only works, but can be improved.
Good judgment can be taught. Tradition held that good judgment was a natural by-product of experience, but as pilots continued to log accident-free flight hours, a corresponding increase of good judgment was assumed. Building upon the foundation of conventional decision-making, ADM enhances the process to decrease the probability of human error and increase the probability of a safe flight. ADM provides a structured, systematic approach to analyzing changes that occur during a flight and how these changes might affect the safe outcome of a flight. The ADM process addresses all aspects of decision-making in the flight deck and identifies the steps involved in good decision-making.
Risk Management
The goal of risk management is to proactively identify safety-related hazards and mitigate the associated risks. Risk management is an important component of ADM. When a pilot follows good decision-making practices, the inherent risk in a flight is reduced or even eliminated. The ability to make good decisions is based upon direct or indirect experience and education. The formal risk management decision-making process involves six steps as shown in the figure below.
Crew Resource Management (CRM) and Single Pilot Resource Management (SRM)
Crew Resource Management (CRM) is the effective use of all available resources for flight crew personnel to assure a safe and efficient operation, reducing error, avoiding stress and increasing efficiency.
CRM was developed as a response to new insights into the causes of aircraft accidents which followed from the introduction of flight data recorders (FDRs) and cockpit voice recorders (CVRs) into modern jet aircraft. Information gathered from these devices has suggested that many accidents do not result from a technical malfunction of the aircraft or its systems, nor from a failure of aircraft handling skills or a lack of technical knowledge on the part of the crew; it appears instead that they are caused by the inability of crews to respond appropriately to the situation in which they find themselves. For example, inadequate communications between crew members and other parties could lead to a loss of situational awareness, a breakdown in teamwork in the aircraft, and, ultimately, to a wrong decision or series of decisions which result in a serious incident or a fatal accident.
The widespread introduction of the dynamic flight simulator as a training aid allowed various new theories about the causes of aircraft accidents to be studied under experimental conditions. On the basis of these results, and in an attempt to remedy the apparent deficiency in crew skills, additional training in flight deck management techniques has been introduced by most airlines. Following a period of experimentation and development, the techniques embraced by the new training became known collectively as CRM. The importance of the CRM concept and the utility of the training in promoting safer and more efficient aircraft operations have now been recognized worldwide.
CRM encompasses a wide range of knowledge, skills and attitudes including communications, loss of situational awareness, problem solving, decision making, and teamwork; together with all the attendant sub-disciplines which each of these areas entails. The elements which comprise CRM are not new but have been recognized in one form or another since aviation began, usually under more general headings such as ‘Airmanship’, ‘Captaincy’, ‘Crew Co-operation’, etc. In the past, however, these terms have not been defined, structured or articulated in a formal way, and CRM can be seen as an attempt to remedy this deficiency.
CRM is concerned not so much with the technical knowledge and skills required to fly and operate an aircraft but rather with the cognitive and interpersonal skills needed to manage the flight within an organised aviation system. In this context, cognitive skills are defined as the mental processes used for gaining and maintaining situational awareness, for solving problems and for taking decisions. Interpersonal skills are regarded as communications and a range of behavioural activities associated with teamwork. In aviation, as in other walks of life, these skill areas often overlap with each other, and they also overlap with the required technical skills. Furthermore, they are not confined to multi-crew aircraft, but also relate to single pilot operations, which invariably need to interface with other aircraft and with various ground support agencies in order to complete their missions successfully.
Classroom training in CRM must be provided in conjunction with simulator revalidation training. Of particular importance is its integration with Line Oriented Flight Training (LOFT), which involves response to realistic scenarios where the application of CRM principles will usually be the road to successfully coping. LOFT details have become a standard component of most commercial operator aircraft type training.
CRM originally was referenced as “cockpit resource management,” but the term was later broadened to encompass the entire crew. While CRM focuses on pilots operating in crew environments, many of the concepts apply to single-pilot operations. Many CRM principles have been successfully applied to single-pilot aircraft and led to the development of Single-Pilot Resource Management (SRM). SRM is defined as the art and science of managing all the resources (both onboard the aircraft and from outside sources) available to a single pilot (prior to and during flight) to ensure the successful outcome of the flight. SRM includes the concepts of ADM, risk management (RM), task management (TM), automation management (AM), controlled flight into terrain (CFIT) awareness, and situational awareness (SA). SRM training helps the pilot maintain situational awareness by managing the automation and associated aircraft control and navigation tasks. This enables the pilot to accurately assess and manage risk and make accurate and timely decisions.
SRM is all about helping pilots learn how to gather information, analyze it, and make decisions. Although the flight is coordinated by a single person and not an onboard flight crew, the use of available resources such as auto-pilot and air traffic control (ATC) replicates the principles of CRM.
