Relative Humidity and Dewpoint
The relative humidity is the amount of water in the air relative to the total (saturation) amount the air can hold at a given temperature. Saturation is the extent to which something is dissolved or absorbed compared with the maximum possible, usually expressed as a percentage. Try putting a spoon of sugar in your tea or coffee, now put another. Keep going until the sugar no longer dissolves. It is now fully saturated, it cannot hold any more sugar. Air that is saturated can no longer hold any more water vapour and is said to have 100 percent relative humidity. Air that has high relative humidity will cause a reduction in aircraft performance.
Dewpoint
The dewpoint is the temperature to which air must be cooled to become saturated with water vapour. It is provided by aviation weather reports in degrees Celsius. When analyzing a weather report, the smaller the difference between the reported temperature and dewpoint, the more humid the air is. This difference is known as the temperature dew point spread. When the temperature of the air is reduced to the dew point, the air is completely saturated and moisture begins to condense out of the air in the form of fog, dew, frost or clouds.
