Operate an aerodrome that is located within the built-up area of a city or town or a land aerodrome that is used by an air operator for the purpose of a scheduled service for the transport of passengers unless an airport certificate is issued in respect of that aerodrome.
Knowingly use an airport in a manner contrary to a condition set out in the airport certificate.
Walk, stand or operate a vehicle/aircraft on the movement area of an aerodrome, except in accordance with permission given by the operator of the aerodrome, and where applicable, by the appropriate air traffic control unit or flight service station.
Tow an aircraft on an active movement area at night unless the aircraft displays operating wingtip, tail and anti-collision lights or is illuminated by lights mounted on the towing vehicle and directed at the aircraft.
Park or otherwise leave an aircraft on an active manoeuvring area at night unless the aircraft displays operating wingtip, tail and anti-collision lights or is illuminated by lanterns suspended from the wingtips, tail and nose of the aircraft.
Knowingly remove, deface, extinguish or interfere with a marker, marking, light or signal that is used at an aerodrome for the purpose of air navigation.
Knowingly display at or in the vicinity of an aerodrome a marker, marking, sign, light or signal that is likely to be hazardous to aviation safety.
Discharge a firearm within or into an aerodrome without the permission of the operator of the aerodrome.
Accessing this course requires a login. Please enter your credentials below!
