Prevention of Runway Incursions
A runway incursion is any occurrence in the airport runway environment involving an aircraft, vehicle, person, or object on the ground that creates a collision hazard or results in a loss of required separation with an aircraft taking off, intending to take off, landing, or intending to land.
It is important to give the same attention to operating on the surface as in other phases of flights. Proper planning can prevent runway incursions and the possibility of a ground collision. A pilot should always be aware of the aircraft’s position on the surface at all times and be aware of other aircraft and vehicle operations on the airport. At times, towered airports can be busy and taxi instructions complex. In this situation, it may be advisable to write down taxi instructions.
The following are some practices to help prevent a runway incursion:
  • Read back all runway crossing and/or hold instructions.
  • Review airport layouts as part of preflight planning, before descending to land and while taxiing, as needed.
  • Know airport signage.
  • Review NOTAM for information on runway/taxiway closures and construction areas.
  • Request progressive taxi instructions from ATC when unsure of the taxi route.
  • Check for traffic before crossing any runway hold line and before entering a taxiway.
  • Turn on aircraft lights and the rotating beacon or strobe lights while taxing.
  • When landing, clear the active runway as soon as possible, then wait for taxi instructions before further movement.
  • Study and use proper phraseology in order to understand and respond to ground control instructions.
  • Write down complex taxi instructions at unfamiliar airports.
