Pressure Gradient Force
The pressure gradient force is the force that results when there is a difference in pressure across a surface. As discussed earlier, a pressure is a force per unit area, across a surface. A difference in pressure across a surface then implies a difference in force, which can result in an acceleration, if there is no additional force to balance it. The resulting force is always directed from the region of higher pressure to the region of lower pressure.
