Nose Wheel Steering
Description
  • A hydraulic actuating cylinder steers the nose wheel.
    • The yellow hydraulic system supplies pressure to the cylinder, and electric signals from the Brake and Steering Control Unit (BSCU) control it.
  • The steering system receives actuating hydraulic pressure when:
    • A/SKID & N/W STRG switch is ON
    • Towing control lever is in normal position
    • At least one engine is running
    • Aircraft is on ground.
  • The handwheel can turn the nosewheel up to 75 ° in either direction.
  • A lever, on the towing electrical box (on nose landing gear), enables ground crew to deactivate the steering system for towing.
    • Then the wheel can be turned 95 ° in either direction.
  • An internal cam mechanism returns the nose wheel to the centered position after takeoff.
