Mountain Waves are defined as oscillations to the lee side (downwind) of high ground resulting from the disturbance in the horizontal airflow caused by the high ground. The wavelength and amplitude of the oscillations depend on many factors including the height of the high ground relative to the surrounding terrain, the wind speed and the instability of the atmosphere.
Vertical currents within the oscillations can reach 2,000 feet/min. The combination of these strong vertical currents and surface friction may cause rotors to form beneath the mountain waves causing severe turbulence, strong vertical currents and icing conditions
