Low Pressure Systems
low pressure system has lower pressure at its centre than the areas around it. Winds converge towards the centre of a low pressure area, and are subsequently forced upwards as shown in the image below. As the air rises, the water vapour within it condenses, forming clouds and often precipitation.
A low pressure system results in a region of converging and rising air. In the northern hemisphere, surface winds within a low pressure system rotate in an anticlockwise direction around its centre.
An area of low pressure is generally associated with poor weather conditions. Lows are sometimes called depressions or cyclones.
