Induction icing consists of any ice accumulation that blocks the venturi, air filter, ducting, and/or fuel metering device. Impact ice, a type of induction icing, can occur anywhere that temperatures are near to, or colder than, the freezing point of 0° C. Impact ice can block the air filter and rob the engine of air needed for combustion, even on a fuel injected engine. If you suspect impact ice, activate alternate air or carburetor heat as directed by your POH/AFM
