Hold Entry Procedures [DELETE]
The pilot is expected to enter a holding pattern according to the aircraft’s heading in relation to the three sectors, recognizing a zone of flexibility of five degrees on either side of the sector boundaries.
Sector 1 procedures (parallel entry) are:
- Upon reaching the fix, turn onto the outbound heading of the holding pattern for the appropriate period of time.
- Turn left to intercept the inbound track or to return directly to the fix.
- On the second arrival over the fix, turn right and follow the holding pattern.
Sector 2 procedures (offset entry) are:
- Upon reaching the fix, turn to a heading that results in a track having an angle of 30° or less from the inbound track reciprocal on the holding side.
- Continue for the appropriate period of time, then turn right to intercept the inbound track and follow the holding pattern.
Sector 3 procedure (direct entry) is:
- Upon reaching the fix, turn right and follow the holding pattern.
Entry procedures to a non-standard pattern requiring left turns are oriented in relation to the 70° line on the holding side, just as in the standard pattern.
REFERENCES AIM RAC 10.5 Entry Procedures
