The pilot-in-command of an aircraft shall ensure that all of the passengers on board the aircraft are briefed before takeoff with respect to the following, where applicable:
- The location and means of operation of emergency and normal exits
- The location and means of operation of safety belts, shoulder harnesses and restraint devices
- The positioning of seats and the securing of seat backs and chair tables
- The stowage of carry-on baggage
- Where the aircraft is unpressurized and it is possible that the flight will require the use of oxygen by the passengers, the location and means of operation of oxygen equipment
- Any prohibition against smoking
- The location and use of first aid kits and survival equipment
- The location and use of any ELT that is required to be carried on board if the aircraft is a small airplane
- The location and use of any life raft that is required to be carried on board
