Moving the ENG1 (ENG2) MASTER switch to OFF directly commands the closing of the LP and HP fuel shut off valves for that engine’s fuel system.
It also closes the fuel return valve and opens the bypass valve.
GENERAL
The FADEC controls the HMU, which :
FUEL FLOW
The Fuel Metering Valve (FMV) transforms FADEC orders through a torque motor and servo valve into fuel flow to the engine fuel nozzles. The FMV resolver generates a feedback signal proportional to the FMV position. The bypass valve maintains a constant pressure drop across the FMV to ensure that the metered fuel flow is proportional to the FMV position.
The FADEC computes the fuel flow that will maintain the target N1. As the FADEC maintains this N1, it allows N2 to vary while remaining between N2 minimum and N2 maximum. The FADEC also controls the engine parameters to :
Some of the fuel flowing out of the HMU goes to cool the oil systems of the Integrated Drive Generators (IDGs). It then returns to the fuel pump unit or to the tank. The Fuel Return Valve (FRV), controlled by the FADEC, ensures that this flow is adequate.
At low engine thrust, if the oil going into the IDG is too hot, the cooling fuel is sent back to the tank (300 kg/h). If oil temperature continues to rise, the ECU increases the minimum N2. If oil temperature still keeps rising, the FADEC increases the fuel flow to the tank (from 300 to 600 kg/h, depending on fuel return temperature). The fuel return valve is always mixing hot fuel with cold fuel so that the temperature of fuel returning to the tank stays below 100 °C (from 200 to 400 kg/h, depending on fuel return temperature).
Fuel recirculation to the tank is inhibited (FRV closed) in the following cases :
