Fuel Injection
More sophisticated engines have fuel directly metered into the induction manifold and then into the cylinders without using a carburetor. This is known as fuel injection. With a fuel injection system, each individual cylinder is provided with a correct mixture via a Fuel Control Unit (FCU), which directs fuel to the cylinder based on the airflow. This allows for tighter control of the desired fuel mixture and ensures improved fuel economy.
Advantages of a fuel injection system include:
  • Reduced susceptibility to icing, however, impact icing  on the intake remains a possibility
  • Reduction in evaporative icing
  • Better fuel flow
  • Faster throttle response
  • Precise control of the mixture
  • Better fuel distribution
  • Easier cold weather starts
Disadvantages include
  • Difficulty in starting a hot engine
  • Vapour lock during ground operations on hot days
  • Problems associated with restarting an engine that quits because of fuel starvation
Fuel Injection System Diagram
