Four Stroke Cycle
In a four-stroke engine, the conversion of chemical energy into mechanical energy occurs over a four-stroke operating cycle.
  • 1. Intake: The intake stroke begins as the piston starts its downward travel. When this happens, the intake valve opens and the fuel-air mixture is drawn into the cylinder.
  • 2. Compression: The compression stroke begins when the intake valve closes, and the piston starts moving back to the top of the cylinder. This phase of the cycle is used to obtain a much greater power output from the fuel-air mixture once it is ignited.
  • 3. Power: The power stroke begins when the fuel-air mixture is ignited. This causes a tremendous pressure increase in the cylinder and forces the piston downward away from the cylinder head, creating the power that turns the crankshaft.
  • 4. Exhaust: The exhaust stroke is used to purge the cylinder of burned gases. It begins when the exhaust valve opens, and the piston starts to move toward the cylinder head once again.
Image courtesy of Wikimedia Commons
