DME Holding Procedures [DELETE]
DME holding is subject to the same entry and holding procedures except that distances, in NM are used in lieu of time values. In describing the direction from the fix on which to hold and the limits of a DME holding pattern, an ATC clearance will specify the DME distance from the navigation aid at which the inbound and outbound legs are to be terminated. The end of each leg is determined by the DME indications.
© Her Majesty the Queen in Right of Canada, as represented by the Minister of Transport. This information has been reproduced with the permission of Transport Canada.
AIM RAC 10.8 Distance Measuring Equipment (DME) Procedures
