Distance Measuring Equipment (DME)
When used in conjunction with the VOR system, DME makes it possible for pilots to determine an accurate geographic position of the aircraft, including the bearing and distance TO or FROM the station. The aircraft DME transmits interrogating radio frequency (RF) pulses, which are received by the DME antenna at the ground facility. The signal triggers ground receiver equipment to respond to the interrogating aircraft. The airborne DME equipment measures the elapsed time between the interrogation signal sent by the aircraft and reception of the reply pulses from the ground station. This time measurement is converted into distance in nautical miles (NM) from the station.
Some DME receivers provide a groundspeed in knots by monitoring the rate of change of the aircraft’s position relative to the ground station. Groundspeed values are accurate only when tracking directly to or from the station.
DME signals are line-of-sight; the mileage readout is the straight line distance from the aircraft to the DME ground facility and is commonly referred to as slant range distance.
Slant range refers to the distance from the aircraft’s antenna to the ground station (A line at an angle to the ground transmitter. GPS systems provide distance as the horizontal measurement from a waypoint to the aircraft. Therefore, at 3,000 feet and 0.5 miles the DME (slant range) would read 0.6 NM while the GPS distance would show the actual horizontal distance of .5 DME. This error is smallest at low altitudes and/or at long ranges. It is greatest when the aircraft is closer to the facility, at which time the DME receiver displays altitude (in NM) above the facility.
