A cold front forms when a cold air mass pushes into a warmer air mass. Cold fronts can produce dramatic changes in the weather. They move fast, up to twice as fast as a warm front. As a cold front moves into an area, the denser cool air pushes under the less dense warm air, causing it to rise up into the troposphere. Lifted warm air ahead of the front produces cumulus or cumulonimbus clouds and thunderstorms
As the cold front passes, winds become gusty. There is a sudden drop in temperature, and also heavy rain, sometimes with hail, thunder, and lightning. Atmospheric pressure changes from falling to rising at the front. After a cold front moves through your area, you may notice that the temperature is cooler, the rain has stopped, and the cumulus clouds are replaced by stratus and stratocumulus clouds or clear skies.
On weather maps, a cold front is represented by a solid blue line with filled-in triangles along it. The triangles are like arrowheads pointing in the direction that the front is moving.
Before Passage | While Passing | After Passage | |
Winds | SSW | Gusty, shifting | WNW |
Temperature | Warm | Sudden drop | Steadily dropping |
Pressure | Dropping steadily | Minimum, the then sharp rise | Rising steadily |
Clouds | Increasing: Ci, Cs and Cb | Cb | Cu |
Precipitation | Short periods of showers | Showery precipitation +RA, GR | Showers then clearing |
Visibility | Fair to poor in haze | Poor, followed by improving | Good, except in showers |
Dew Point | High, remains steady | Sharp drop | Dropping |
