Basics of Heat Transfer
Much of the weather we experience is due to the uneven heating of hearth surface. However, before diving too deep into how the Earth is heated, it will be beneficial to first study the basics of how heat is transferred.
Radiation
Thermal radiation is electromagnetic radiation generated by the thermal motion of particles in matter. All matter with a temperature greater than absolute zero (-273 °C) emits thermal radiation. Upcoming topics will discuss solar and terrestrial radiation.
Conduction
Thermal conduction is the transfer of internal energy by microscopic collisions of particles and movement of electrons within a body. Conduction takes place in all phases: solid, liquid, and gas. Heat spontaneously flows from a hotter to a colder body. For example, heat is conducted from the hotplate of an electric stove to the bottom of a saucepan in contact with it. In the absence of an opposing external driving energy source, within a body or between bodies, temperature differences decay over time, and thermal equilibrium is approached, temperature becoming more uniform. In conduction, the heat flow is within and through the body itself. In contrast, in heat transfer by thermal radiation, the transfer is often between bodies, which may be separated spatially.
Convection
Convection is the transfer of heat from one place to another due to the movement of fluid. Although often discussed as a distinct method of heat transfer, convective heat transfer involves the combined processes of conduction and advection. When a fluid is in contact with a hot surface, its molecules separate and scatter, causing the fluid to be less dense. As a consequence, the fluid is displaced while the cooler fluid gets denser and the fluid sinks. Thus, the hotter volume transfers heat towards the cooler volume of that fluid. Familiar examples are the upward flow of air due to a fire or hot object and the circulation of water in a pot that is heated from below.
