Ammeter and Load Meter
An ammeter is used to monitor the performance of the aircraft’s electrical system. The ammeter shows if the alternator/ generator is producing an adequate supply of electrical power. It also indicates whether or not the battery is receiving an electrical charge.
An ammeter is used to monitor the performance of the aircraft electrical system.
Ammeters are designed with the zero point in the center of the face and a negative or positive indication on either side. When the pointer of the ammeter is on the plus side, it shows the charging rate of the battery. A minus indication means more current is being drawn from the battery than is being replaced. A full-scale minus deflection indicates a malfunction of the alternator/generator. A full-scale positive deflection indicates a malfunction of the regulator. In either case, consult the AFM/POH for appropriate action to be taken.
Not all aircraft are equipped with an ammeter. Some have a warning light that, when lighted, indicates a discharge in the system as a generator/alternator malfunction. Refer to the AFM/POH for appropriate action to be taken.
Another electrical monitoring indicator is a load meter. This type of gauge has a scale beginning with zero and shows the load being placed on the alternator/generator. The load meter reflects the total percentage of the load placed on the generating capacity of the electrical system by the electrical accessories and battery. When all electrical components are turned off, it reflects only the amount of charging current demanded by the battery.
A voltage regulator controls the rate of charge to the battery by stabilizing the generator or alternator electrical output. The generator/alternator voltage output should be higher than the battery voltage. For example, a 12-volt battery would be fed by a generator/alternator system of approximately 14 volts. The difference in voltage keeps the battery charged.
